I have oil in my intake runners please help!
#22
Originally Posted by hog
Maybe you dont hav ethe proper main bearing clearances, they are smaller on the GEN 3 engines than the GEN 1, Gen 1E or GEN 2 engines.
peace
Hog
peace
Hog
#23
How about the oil pump pickup tube o-ring? I know alot of guys have had issues with different size/style o-rings not fitting properly. I'd also check and make sure it's in straight and not kinked.
BTW, I did more research on those intake rocker bolt holes, and it's common and normal for ported heads. Some liquid teflon or other sort of sealer should fix you up.
#25
Originally Posted by Dbl G
You might try this...
Any hoses, lines, or hardware come with it?
Is that a universal bracket or is it designed to mount in a specific location for our GM trucks?
How is it emptied? Valve or do you actually have to remove it from the bracket to be emptied?
Jim
#27
when i replaced the Knock Sensors on my 5.3, i noticed something puddled in the rear of the intake.. i got a blue shop rag, taped it to the end of a long screwdriver and cleaned it out.. it was black oil.. so i just put everything back together and been runnin the crap out of it like usual... poor motor.. the throttle still sticks closed.. i clean it ever oil change.. and it always starts stickin right before i change the oil.. what gives with this?? is it just from running it hard all the time? or is this common?
i just clean it and keep on goin..
Have u cleaned the tb and IAC?
I only have 24k but probably will do a Sea Foam pretty soon. Good luck,guys,on your problems!
Corvette454l88
09-01-2016 01:24 AM
jroctpb
08-11-2015 03:52 PM
05GMC4.8
08-07-2015 09:55 PM
