i have search but to no luck (6.0 cam choice)
Old 02-12-2012, 10:11 PM
  #21
Where's the Beef?
viciousknid's Avatar
I have a 224/230 610/605 111+3 in my stock 5.3 and it made 340rwhp @ 6300-6400 and was holding steady at 6400 when we let out. Shifting at 6800. I'd gladly run that in a 6.0. Made more hp and tq over the entire curve than a 216/220 525/532 114.
Put together a graph that compared the 2 cams with the same setup. If I remember correctly the only difference is that the Comp 216/220 cam we dyno'd in 3rd gear with cutouts open and the Eps 224/230 we did in 2nd. Would have made more power in 3rd.
Old 02-12-2012, 10:39 PM
  #22
greenz71's Avatar
What springs are you running with that eps cam?
Old 02-13-2012, 01:39 AM
  #23
Vortec350ss's Avatar
Thats a big *** cam in a 5.3! How it is down low? Do you have any drivability issues? How high do you rev that thing??
Old 02-13-2012, 01:41 AM
  #24
13 Second Truck Club
A Low Dime's Avatar
Thats an awesome graph!! Great way to see the differences, I wish you they both would have been in 3rd, but still shows enough gain regardless.
Old 02-13-2012, 10:29 PM
  #25
bluebommer07's Avatar
Thats basically the same cam I'm running and I love it. Mine has slightly different specs and I had it done custom by Pat G. Its got a slightly wider LSA with a cam lobe that is designed to make less noise on the exhaust side.
what do u mean less noise on exhaust side?
Old 02-13-2012, 10:41 PM
  #26
grey matter 04's Avatar
used pat g and geoffs lobe that is easier and smoother on valvetrain
Read on EPS website the solution explains
http://www.engpwrsys.com/tech-notes/cam-design.html
Old 02-14-2012, 06:07 AM
  #27
Engine Power Systems, 2010 Camaro Parts, 2010 Camaro Accessories, LS1, LS2, LS3, LS6, LS7, LS9 Dyno Tuning, Custom LSX Camshafts, Baton Rouge Louisiana - Cam Design
just read it now it makes more since on why he said that thanks. for pointing that out
Old 02-14-2012, 08:14 AM
  #28
iamkeniff's Avatar
222/226 shift it at 6500 an let it do what it does if you want a torque setup run the trucker cam (high lift) an let it ride. No need to over cam a truck that isnt a race truck muchless put a cam you have to spin to 6800-7000 to get peak power out of.
Ive told you a million times the 222/226 is the biggest id run without a set of heads. You're wanting a budget build an ive pointed it out a ton of times.
243s stock
222/226 eps cam or trucker high lift
3000-3200 converter
Leave the 3:73s an put a tru-trac.
Do your other bolt ons and leave it alone.
Old 02-14-2012, 09:48 AM
  #29
Lmao I know its been more like a billion times u told me, but I just wanted to see what everyone options were to a simple build.
Old 02-14-2012, 10:15 AM
  #30
243s stock
3000-3200 converter
I like the sounds of that build... it would run real strong in your truck. Like 12's with good weather and traction...
Quick Reply: i have search but to no luck (6.0 cam choice)
