I heard you can't pull heavy loads with a turbo
Old 01-26-2005 | 06:51 PM
  #21
TurboBerserker's Avatar
I AM A MOTHERF*CKER
... pulling your boat
Old 01-26-2005 | 07:24 PM
  #22
the guy that i talked to was from Livernois Motorsports.
Old 01-26-2005 | 07:54 PM
  #23
JERRY2500's Avatar
14 Second Truck Club
Thats because he sells thesehttps://ls1tech.com/forums/showthread.php?t=267037 It is a nice setup.
Old 01-26-2005 | 08:03 PM
  #24
one03sierra's Avatar
Formerly one92rs
Talking
i thought that on the website the front page was a truck with a boat behind it.
Old 01-26-2005 | 08:10 PM
  #25
parish8's Avatar
single digit dreamer
i think there is a problem with towing or at least this isn't the first i have heard that you have to be careful. you would not want to take my truck and load it to 15000lb's and try and tow up a steep grade. it would make the power for it easy but wouldn't take long for things to get ugly. i think if it was turned down to a safe 5psi or so that it would be ok but maybe not. the thing is with the turbo you would be tempted to hit that hill at 70mph because it would do it but the heat would be building fast.
i think with a cast iron manifolds and limited boost you would be ok like the sts kit.
Old 01-26-2005 | 08:17 PM
  #26
JERRY2500's Avatar
Like you said , I'm only Pushing 5# boost and the turbo being that far back it doesn't heat up as much as it would with your set up. BTW I like how your setup runs. Good race truck. I'm just set up for towing and a little street racing. Got to love that turbo.
Old 01-26-2005 | 09:44 PM
  #27
Default thats what an EGT gauge is for
when I pull I just keep my EGT gauge under 900 degrees, an adjust my driving .
Old 01-26-2005 | 11:16 PM
  #28
moregrip's Avatar
what a rush!
Originally Posted by F8L Z71
You'd have LOVED to hear my pitch to my buddy about how he should get a Radix for his 02' 2500HD. I drove it for a week while moving into a new house and I would daydream durring my trips back and forth with loads to the new house. I think I almost have him hooked. You'd would have fainted when I told him for his application he'd be happier with the Radix.....
say what
Old 01-27-2005 | 12:50 AM
  #29
F8L Z71's Avatar
Originally Posted by moregrip
say what
He uses his truck to tow his race car and he loves to drive through HUGE puddles and sling mud on people. He is never going to add a converter or a cam or any other stuff to the truck and he needs it to be smog legal. The Radix was a no brainer for him. His truck has ok top end but the bottom end feels like you're already towing a 5klb trailer even when nothing is attached! As much as I give you guys **** about my STS being better I like the Radix and know when a person should get it over another brand. :p
Old 01-27-2005 | 09:42 AM
  #30
marc_w's Avatar
Anyone see the TV show about the Banks twin kit for the SBC?
Here is the kit: http://www.bankspower.com/twin-turbo-products.cfm
Check out the exhaust manifolds... http://www.bankspower.com/twin-turbo-system.cfm
On the TV show (HP TV or something?), they mentioned that the exhaust side of a turbo can easily glow from heat - they said Banks designed these things so they won't sag from the turbo's weight, with all of the heat generated under heavy loads.
I think that is the limiting factory with front-mounts... a strong enough header/log/manifold system.
Quick Reply: I heard you can't pull heavy loads with a turbo
