i need cam swap for dummies!
Old 09-09-2008, 09:24 AM
Mark Johnson's Avatar
What about the pushrods? Aren't they marginal at best on a stocker? Are stock LS1 pushrods better than our truck parts..........
Old 09-09-2008, 11:15 AM
PT's Slowest Truck
budhayes3's Avatar
Marginal at best IMO. Go for some hardened rods.
Old 09-09-2008, 11:40 AM
InchUp's Avatar
I don't have a wild camshaft but I'm using the stock 5.3L pushrods for my 206/212 XR259. I think more has to do with the aggressiveness of the camshaft, in which case neither the XR259 nor the XR265 (his 212/218) are very aggressive. It'll be quite aggressive in his 4.8L, but that's because of the lack in displacement. You put that same 212/218 in a 6.0L and it'll go from a high winding 4.8L cam to a low rpm torque monster in a 6.0L.
Old 09-09-2008, 12:17 PM
jdawg04 4.8's Avatar
the 212/218 low lift is a fun cam in the 4.8 (mods in sig) it does lack low end even more so becuase i was running a stock stall and my trucks on 22s. But the truck loved it when i went above 3000 it just would run strong.
Ill be using the same cam in my LQ9 (swap should be done Fri) i cant wait to finally have some ***** off the line if traction isnt to much of an issue it should be a good combo.
Old 09-09-2008, 01:17 PM
sickREDsierra's Avatar
it will be!!!
Old 09-09-2008, 03:37 PM
Im thinking that the heavy a$$ 22s and the 305s out back will help a little.
OHsixLS3
12-27-2016 09:30 AM
GrooveCityZ71
08-31-2015 12:05 PM
WICK3DxGATA
07-21-2015 06:59 PM
Aboss
07-09-2015 10:28 AM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: i need cam swap for dummies!
