I need motor swap ideas on a tahoe
I just got a 99 police tahoe and was told the motor is messed up but have not yet had a chance to check it out to see what is wrong with it. So if the motor is messed up I was thinking about swaping the 5.7 to a 6.0 but was not sure if it was posible? I am on a small budget because I am in the process in buying another house. So would it be easier to just beef up another 5.7, throw a 6.0 in it or is there another option ot there? I also would need it street legal and pass emissions. Any help would be appreciated and links to anything would help even more thanks.
I have a gauge for that
I helped a friend of mine swap a 6.0 into his 99 obs tahoe. The main issues were you need brackets for the motor mounts, the correct flexplate if you plan to still use the LT1 trans, and a wiring harness for the new computer.
The stock fuel pump on your tahoe should be plenty for a stock 6.0L if it isn't already on the way out. A member on another forum ran a ramjet 502 with a 200 shot in his 2000 Tahoe limited (which is basically a police tahoe like yours) and didn't have fueling issues with the stock pump. I had no issues either with the stock pump on my previous setup with the whipple at 10 psi. I am planning on running the stock pump with the heads/cam 6.0L I'm swapping in.
Lots of places out there that offer 383 stroker kits, too many to count. I don't want to post non-sponsor links. You want a kit that is for a 1 piece rear main seal block. I prefer 6" rods over the factory 5.7" rods as there is less cyl wall thrust with a longer rod. That coupled with a zz4 camshaft, new valvesprings, headers, and a tune and you should have a torquey tahoe.
After further research it looks like I am going to go with a 383 stroker because the cost for the 6.0 swap is not there. I am buying a house and still am trying to put my typhoon back together. Maybe once I get tired of the 383 I will throw in the 6.0 with a 4l80 in the hoe?
