I Need Your Help. 408 Stroker Wont Run.
#31
Well cue the I TOLD YOU SO!!!
I disabled all of the injectors and went cylinder by cylinder based of your suggestions. 1-7 sounded great, but found an issue with 2 & 8. Turns out when I fixed the initial coil pack ground, and changed the plugs I flipped the passenger side coil pack harness🤦🏻♂️🤦🏻♂️🤦🏻♂️.
i checked it multiple times but apparently the more you mess with something the more you actually mess it up 😂😂.
I am glad it is running and can’t thank you enough for all of the help and ideas!!
The following 3 users liked this post by DrocheGMC:
darkirish63 (10-23-2020)
#34
dantheman1540 (10-23-2020)
Bgbldodge (10-23-2020)
#38
Here are some build pictures as well. The engine bay is not finished, there is a lot of tidying up to do, I just was to anxious and wanted to start the motor ahaha.
Also does anyone have suggestions on a CAI for the Holley High Ram?
