I think it's about time to change the oil...
Old 03-29-2010, 05:31 PM
12 Second Club
AdioSS's Avatar
Default I think it's about time to change the oil...
I've been considering sending this batch in to be tested to see if it really is a good idea to trust the built-in meter...
Old 03-29-2010, 06:06 PM
PT's Slowest Truck
budhayes3's Avatar
Go for it man, and post up your results...I'm curious too. I'll bet that it checks out OK though
Old 03-29-2010, 06:10 PM
slamdlsx's Avatar
mine has no meter boooo.
Old 03-29-2010, 06:15 PM
Dewey's Avatar
I'm pretty sure that's only on the 03+ models. i think you should go to synthetic and see if it makes a difference in the meter's readings.
Old 03-29-2010, 06:33 PM
jiar577's Avatar
I did it and makes no difference on the reading.
Old 03-29-2010, 06:41 PM
Dewey's Avatar
ok then my vote goes to no for trusting the reading's accuracy.
Old 03-29-2010, 07:05 PM
Wearin' da big hat
00ChevyScott's Avatar
Better to change it early than late, that's what I say.
Old 03-29-2010, 07:13 PM
slamdlsx's Avatar
Mines an 04 I thought it would have it but guess not
Old 03-29-2010, 07:15 PM
Wearin' da big hat
03-04 still had the limited cluster stuff I believe. 05+ got all the cool stuff, bastards.
Old 03-29-2010, 08:16 PM
MikeGyver's Avatar
My 2000 just says CHANGE OIL (!)
GM says oil life is determined by:
1. How long you are at what rpm,
2. How long you are at what throttle position, and
3. How many miles.
So if you never rev it over 2000, never give it more than 25% throttle, it will probably be 10,000 miles before it tells you to change the oil.
Mine usually is 6000-7500 miles, which is fine by me since I only use Mobil 1 5w-30.
Quick Reply: I think it's about time to change the oil...
