If this doesn't fix it I give up
Old 10-05-2009, 07:48 PM
  #91
hirdlej's Avatar
I just wanted to make sure you didn't have this goin' on...........
Old 10-05-2009, 07:49 PM
  #92
Baltimore Whore
Mangled03gmc's Avatar
Knock knock???? whos there??? I dunno but i can't get rid of it.. babahahahahahwhaawwawaw... Seriously I do hope you get it fig out. I know it can drive a **** nuts..
Old 10-05-2009, 08:00 PM
  #93
GMCtrk's Avatar
I look forward to making 600+ rwhp with these heads. I may eventually have them sent out to someone to port the combustion chambers and stick in some bigger valves.
Old 10-05-2009, 08:08 PM
  #94
nonnieselman's Avatar
you still goin forced induction?
Old 10-05-2009, 08:09 PM
  #95
Resident Retard
BlackGMC's Avatar
Originally Posted by GMCtrk
Sure Corey
wanna post the tune?
Old 10-05-2009, 08:12 PM
  #96
GMCtrk's Avatar
Sure thing. To the base tune I pasted in the low octane table into the high octane table, the other one I stuck a 2002 Zo6 high octane table into the LQ4 high octane table
File Type: tun
File Type: tun
File Type: tun
Old 10-05-2009, 08:16 PM
  #97
Resident Retard
BlackGMC's Avatar
did you do all those logs on the same day right after eachother? If so what order did you log them in??? I think i might have an idea...
Old 10-05-2009, 08:17 PM
  #98
GMCtrk's Avatar
My first priority is to get this thing running right, with no KR.
After that I will decide on the further plans. I'm still considering a big inch LSX engine built for boost. HKE has a 434" LSX that supposedly can handle 1500-2000 HP for $6600
  #99
GMCtrk's Avatar
I did low octane log 1 first then the high octane log, then low octane log 2
It just makes no sense that it will knock with 22.5 degrees of timing yet I went WOT a couple times with 27 degrees of timing with no KR
Old 10-05-2009, 08:20 PM
  #100
Resident Retard
BlackGMC's Avatar
What does your exhaust setup consist of?
Quick Reply: If this doesn't fix it I give up
