If this doesn't fix it I give up
#123
Resident Retard
I am not trying to be a dick or anything.... It is jsut kinda painful reading your threads over and over again... And once again 880mv is not 12.0 AFR or anywhere close it is more like 13.0....
#127
PT's Slowest Truck
The wideband is definitely a good idea, I'd listen to Corey on this one. Get the catch can too, just to keep the oil out of your intake and combution chambers...as I've mentioned to you I think they should come with one from the factory lol. But the first thing I'd do, if the O2 readings are going lean, is get a mechanical fuel pressure gauge, the universal ones that screw into the fitting on the fuel rail are pretty cheap...check out thetoolwarehouse dot net, I buy a lot of tools from there at great prices. Good luck Michael, I'm sure that when you figure it out you'll probably say "why didn't I think of that first?!"
Oh yea, I hate descreened MAF's, everything I've heard has been negative, and I've heard that they can make tuning a bitch...can you go speed density for the time being? (I'm a noob with tuning, so if that's a stupid question, forgive me)
#130
Wearin' da big hat
Why don't you try loading in a bone stock LQ9 tune, just for ***** and giggles. It probably won't even be close, but it'd be worth a shot.
