If this doesn't fix it I give up
#31
Well ****! lets try the higher octance first, if still present then gotta look at common things that will cause a "knock" (I'm sure you already have) carbon deposits, loose mounts, loose tc bolts, exhaust hitting on frame at WOT bc of loose mounts, electrical wiring, BAD PCM(may be not) after that...... teardown I guess!
Let us know what you find
