Im puffin' smoke sandy...
BRING IT ON ME...I'D DO IT FOR YOU! -Willem Defoe
Well...motor bit the dust big time yest. WOT uphill run resulted in white smoke out the exhaust...parked it and left it running for sec...oil pressure and temps looked fine and accept for the BIG CLOUD of thick white smoke and dancing idle seemed fine...then I noticed the oil blowing out the exhaust on the ground and dripping off the headers
. Shut her down and the dip stick was dry. Only hint I had that something might be iffy was that the meth light next to my boost guage that glows red @ 5lbs and green @ 7+ was blinking on the run (tank was full).
...so result is its parked until I get rich enuf to no longer worry about the black hole it represents
![Cry](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cry.gif)
