Injector dammaged?
Injector dammaged?
I had the gasket between the upper and lower housing for the intercooler go so I have to separate the intercooler this past weekend. When I pulled the fuel rail and injectors I noticed on one of the injectors, the hard plastic/rubber tapered section just below the lower o-ring on the nose had a gouge in it. The o-rings all looked looked fine though. Should I be concerned about this (is that a sealing surface or is the oring what seals the injector) or can I try to work it over and put it back in. I didn’t start pulling to see if I could pull that tapered section off. I’m thinking of putting it back in one of the front holes so If I have to replace it I can.
