injector help
Old 03-09-2010, 08:35 PM
02Denali6L's Avatar
Default injector help
I have an LQ4 in a 2002 sierra denali. It is the original motor and harness. What is the name of the injector connection do I have? Also, what oversized injector can I use that is a direct plug-in not requiring adapter plugs?
Thanks
Old 03-09-2010, 08:54 PM
gao8302's Avatar
If your going with a Procharger get yourself some 60's. I just did the swap this weekend with some siemans Deka 60's. They are the car style so you have to change the harness. Its really an easy install. only took 2 hours to get it all done. Think about it
Old 03-09-2010, 09:41 PM
BlownChevySS's Avatar
They are the small little square plugs. I am not sure of the type. I just know they are not ev1 or ev6 type. Only person I know who sells a plug n play 60# injectors is SRT10KILLR. I'd pm him for info.
Old 03-09-2010, 10:05 PM
02Denali6L's Avatar
Thanks
Old 03-09-2010, 10:37 PM
Baltimore Whore
Mangled03gmc's Avatar
A lq4?? didn't the sierra denalis come with the lq9's??
Old 03-09-2010, 10:52 PM
TurboGibbs's Avatar
I don't think the LQ9 came out until 03.
Old 03-09-2010, 11:07 PM
02Denali6L's Avatar
I have found "multec 2" as the connector. Everyone lists either EV1 or EV6 as adapters. I guess only Delphi injectors can be plug and play.
Old 03-10-2010, 08:07 AM
TurboGibbs's Avatar
The 8.1 Marine injectors are the only plug and play for the trucks I'm aware of. They are 42 lbs I believe. They are what comes in a MP112.
Old 03-12-2010, 12:18 AM
hobbesnmina2001's Avatar
Fuel Injection Connection can resize your stock or get you rebuilt stock types and flow matched. They just did it for my Vette for plug and play other then adjusting the tune.
Old 03-12-2010, 10:14 AM
FormerVendor
KLUG'S SS's Avatar
The last I knew FIC could not resize the delphi injectors that come in the trucks, I would not ever go that route anyways but I was just curious so I gave them a call and asked one day awhile back.
Quick Reply: injector help
