Injector question.
Injector question.
I got these 42lb to replace my stock ones and they dont even come close to fitting any ideas on what i can do, The pig tails wont plug into them and they are way taller then the stock ones. Heres what im working with any help..
those are 42lb ford lightning injectors.. they are 42lb are 43psi..they would be around 48lb injectors at 58 psi..to run that injectors you need an ls1 style intake...how much you want for them?
Thats odd Blownchevy must have boxed up the wrong ones.. I need the right injectors if you have any 42lbs ill trade you straight across if you need them. Let me know
Yep, ford green tops, you can use them by changing the pigtails on your wires, or get a hold of whipple496 and he can probably hook you up with some plug and play adapters. That's what I used on my 60's. You will also need to make some 5/8" spacers and longer bolts for the fuel rails.
Damn thought id make it through my first tear down and rebuild with no big hiccups guess i should have known better . Im tuned for 42's i cant run the stock ones can i it would run like chit.
