injectors off 2003 5.3 not fitting on 2002 5.3?
Old 01-10-2012 | 01:38 AM
  #21
TXjeepTJ's Avatar
Pull one of them injectors out, give me a measurement, I have like 4 sets of stock injectors in the garage.. I will go take a check also.. The only diff I see is that fuel rail is raw in color and not black.. Other then that it looks the same to a 03 back one.. Has the FPR on the side, the little plate that holds the cross over in with the O-ring..
2 1/4 inch long
Old 01-10-2012 | 01:39 AM
  #22
TXjeepTJ's Avatar
Originally Posted by AKlowriderZ71
What heads are on the engine?
stock heads, 862
Old 01-10-2012 | 01:42 AM
  #23
Mangled03gmc's Avatar
Baltimore Whore
2 5/16'' ruffly
Old 01-10-2012 | 01:44 AM
  #24
TXjeepTJ's Avatar
2 5/16'' ruffly
so I'd call it pretty much the same length lol, I don't think 1/16" would make that much of a difference when compared to how far they need to move down into the intake on this manifold/fuel setup
Old 01-10-2012 | 01:49 AM
  #25
Baltimore Whore
I can't remember ever seeing a FPR with the nipple straight out of it like his. They usually all point up.
you said nipple... Yah strange for sure.. Like the fuel rails are not correct, as now I can clearly see from the pic they are infact short.. I was going to say if it was a returnless set up I have a NEW intake-rails-injectors.. But its not
Old 01-10-2012 | 01:53 AM
  #26
TXjeepTJ's Avatar
It is a returnless setup, the shop used a 1998 C5 vette regulator/filter at the tank to regulate the pressure to 58psi. Then they plugged off the return line @ the intake regulator and didn't connect vacuum to the regulator
Fuel pressure at the fuel rails is 58psi constant using the method they did
thanks for all the help so far mangled!
Old 01-10-2012 | 02:09 AM
  #27
Baltimore Whore
Are you serious.. That is hack job.. Tell that guy I have a NEW set up and will let it go cheap.. Not trying to boast a sale, but i certainly wouldn't want my chit hacked like that.
Old 01-10-2012 | 02:10 AM
  #28
AKlowriderZ71's Avatar
11 Second Hall Moniter
Whoa. That's a messed up way to design a fuel system.
What is the end result you are looking for? How do you want the fuel system to be set up when you're finished?
Old 01-10-2012 | 04:26 AM
  #29
TXjeepTJ's Avatar
End result would be to return everything to how the engine was from factory as far as the intake/rails/injectors
Old 01-10-2012 | 10:45 AM
  #30
graysilverado5.3's Avatar
Have you tried changing out the o rings? A buddy once used my injectors(2005 5.3) on his(2001 5.3) intake, and they didn't fit. He had to use his original o rings. My o rings were thicker than his if I remember correctly so they didn't want to seat on the intake.
