injectors off 2003 5.3 not fitting on 2002 5.3?
#21
Pull one of them injectors out, give me a measurement, I have like 4 sets of stock injectors in the garage.. I will go take a check also.. The only diff I see is that fuel rail is raw in color and not black.. Other then that it looks the same to a 03 back one.. Has the FPR on the side, the little plate that holds the cross over in with the O-ring..
#25
Baltimore Whore
you said nipple... Yah strange for sure.. Like the fuel rails are not correct, as now I can clearly see from the pic they are infact short.. I was going to say if it was a returnless set up I have a NEW intake-rails-injectors.. But its not
#26
Fuel pressure at the fuel rails is 58psi constant using the method they did
thanks for all the help so far mangled!
#27
Baltimore Whore
Are you serious.. That is hack job.. Tell that guy I have a NEW set up and will let it go cheap.. Not trying to boast a sale, but i certainly wouldn't want my chit hacked like that.
#30
Have you tried changing out the o rings? A buddy once used my injectors(2005 5.3) on his(2001 5.3) intake, and they didn't fit. He had to use his original o rings. My o rings were thicker than his if I remember correctly so they didn't want to seat on the intake.
