inline fuel cooler
Oh ****, now I see. I forgot about Atomic's transfer case fiasco.
I've always been a skeptic about cooling fuel and especially adding more connections to a readily combustible system..... I know with water it absorbs much more energy when it vaporizes. Gasoline doesn't have near the same latent heat though.
I know and I've thought about it too, the connections that is. The one thing I do know is that with a wet flow intake the gas has a major cooling effect on it. Its sort of like cracking open a can of R12 and spraying it on a shop towel. Aside from the added connections I really can't think of any adverse effects of adding the cooler from a performance stand point.
Maybe I should just use it as a power steering cooler when I put the hydroboost on.
Simple just like the pressure cooker mom used to use. Pressurizing a liquid raises its boiling point. Same thing as a 16 pound cap on a radiator.
I have a gauge for that
I need an example. Remembering back to grade school science IIRC a liquid will compress a very small amount in contrast to a gas which easily compresses and rexpands.
