Innovative LC-1 wideband hookup questions?
I've got an innovative lc-1 wideband and my hptuners eio cable will be here within a few days. I had the bung welded into my x pipe which unfortunately is after the cats and before the muffler. Can anyone tell me EXACTLY how they hooked it up? which wired go where etc. Thanks in advance.
I don't have the Innovative model but most/all the wideband kits are nearly plug and play. The harness from the wideband will come with the proper connections for a "one wire" hookup. Since the Innovative uses a hand held monitor, I would think it only needs batteries, no tapping into a 12V source and ground.
Now if you want to hook the wideband up to your stock computer for narrow band monitoring, that is a little different. The kit should define how to do this tho....
iregret
09-07-2015 01:20 PM
madmann26
09-06-2015 04:19 PM
