Input Needed: Building 243 Heads for High Revving Twin Turbo LR4 build
#32
Yea I'll check on this. If they work I'm in good shape. I'd prefer to stay flat top, but I just want to hone it, not bore. So I guess -2cc is what I'm stuck with.
#33
I messaged LME and Texas-Speed about the pistons.
TS got back to me and said "I don’t know of anyone that will sell a piston for the stock displacement 4.8l. No one wants to make a piston setup for the different stroke unless you go custom."
Damn it. What the hell are the guys running here for pistons? I see plenty of turbo guys running 9's 10's at the track w/the 4.8L.
#35
I plan to keep the stock rods.
The prices are much more reasonable than expected.
$110 per piston, $15 each to have them coated, and about $20 per ring.
I'm looking at $1160 for the set. Not too bad for custom.
#37
If this works out pretty good, you better believe I will oversquare build my next motor pretty nice!
#38
Un-Registered User
#39
So the stock pistons really hold up that good? If I just stuck with them I should be fine? I mean, guys are doing it.
It would save me $1000+ if I did. if I gap the rings it should keep the heat pretty low.
Problem is I only plan to run pump 93 gas, or e85 without any meth injection.
Would the 9/10/11's be obtainable without the meth?
Thanks
Thanks
