installed radix, no start up
i installed the radix yesterday, put in allen tune tune and did not get a fire up.
the motor was turning over, but no spark we think was being produced, but we didnt mess with that at all during install.... we took out the FPR and we had fuel pressure. i talked to brian and he thinks it has something to do with VATS...
the truck is running WAy rich, we had to throw the original PCM back in... so now it wont hold idle on start up and the SES is on.
got a PM from allen saying how to do pass key on the new PCM, but my security light isnt coming on, so i'm am unable to do pass key right now. i think i'll have to throw in the old PCM and wait for another tune.
here is the link for the pass key: (is this correct)
http://www.nelsonperformance.com/faqs/passkey.htm
That link is correct, but the security light should be one in the sequence. Mine flashes between battery and security. Mine also starts for one second then dies. Is it the superchips tune (or at least the one in the superchips handheld, not sure if it actually is a superchips tune) running way rich??
For some reason the pass key procedure is different on some trucks. When I put a new pcm in mine I only had to turn the key to the on (not all the way to start) position before the security lite would come on and I could finish the procedure. (took me a bit to figure that one out). After doing that three times, Then it fired right up.
i tried turning the key to on.. still no security screen.... what the heck is going?!?!?
i'm not sure if this even has to do with vats now... its turning over fine.. just no fire up... ugh............
Originally Posted by LS1csherm
I had to do the pass key with my new tune
3 times it would burp - let it sit 10 min - fired on the 4th try
i'm going to try again later today after work.
Hey Bryce do you have any other security alarm stuff on there? I remember I kept having to hit unlock on the key fob brfore you could crank it. Do you have to hit unlock everytime you try the vats stuff? I know it might be a last resort by far because they suck, but could you take it to a dealer to have them figure the vats out?
Ryan.
Ryan.
