installed TR6's, now bad idle.
Old 11-10-2004, 03:17 PM
14 Second Truck Club
onyx's Avatar
ill probably just go buy new wires. and see if that helps
Old 11-10-2004, 03:25 PM
JERRY2500's Avatar
Proubly bad wires i had to change mine right after changing the plugs because it was missing.
Old 11-10-2004, 03:26 PM
marc_w's Avatar
If you guys have an ohm-meter, you can just measure the resistance on them... they should be between 400 and 800.
Aftermarket wires (MSD, Taylor) should be much less than that. (25-50ohms)
Old 11-10-2004, 03:40 PM
onyx's Avatar
Originally Posted by Pewter53
try to drive it past 65 if it is a boot or wire you will get a ses light and it will go no faster it will just die at 65.
yup, i just took it out and thats what it did... wouldnt go past 65... so i bought some boschs with lifetime warranty and got some dielectric grease, about to change em out... keep your fingers crossed.
Old 11-10-2004, 03:51 PM
marc_w's Avatar
Mine was a pile of crap with the cracked insulator... wouldn't get out of it's own way.
It sounds like either a plug or a wire is definitely bad.
Old 11-10-2004, 03:59 PM
onyx's Avatar
the insulator is?
Old 11-10-2004, 04:02 PM
onyx's Avatar
well i started her up and its still doin it... ugh.... i put it in reverse and it starts to clunk and the lights flicker like it wants to die.
Old 11-10-2004, 04:08 PM
JERRY2500's Avatar
You may have to reset the pcm to clear any codes.
Old 11-10-2004, 04:09 PM
onyx's Avatar
i'll try it...
Old 11-10-2004, 04:10 PM
single digit dreamer
parish8's Avatar
better pull them out and take a look, maybe you bumped one of the ground straps or something.
the 6's do idle slighly worse than stock. 7's idle much worse than stock. noticable miss.
Quick Reply: installed TR6's, now bad idle.
