installed TR6's, now bad idle.
#21
14 Second Truck Club
battery is disconnected. should i change out my old plugs?... ugh thgis sucks... at least i'll still be able to get to work... i dont live to far.
#22
Originally Posted by parish8
better pull them out and take a look, maybe you bumped one of the ground straps or something.
the 6's do idle slighly worse than stock. 7's idle much worse than stock. noticable miss.
ground straps?
#26
PT's Slowest Truck
I'd pull all of the plugs and check for a cracked insulator (porcelain) or a gap slammed shut. Wierd how you say it only happens in reverse...I've seen that happen with a loose or broken intake tube. When the vehicle is in drive it idles fine because the intake tube is sealed, but when it's in reverse the engine torques and the tube opens up letting in unmetered air...just a thought.
#27
well.. i found a cracked insulator.. hopefully its only one.. i'll put one of my old 55's back in and see if that does it.. if it does then im going to have to buy another 6
#29
welp.. its fixed now.... i had a couple cracked insulators.... 5 actually..... heh.. um.. so i learned a life lesson today. dont overtorque your spark plugs.
