Installing Addtional driving lights. Anything I should know?
what lights are you planning to install?
Most, you can run a dedicated line from the + terminal, to a fuse then a switch, and you are golden. If you have multiple sets, and arent going to pull an assload of current, you can also put in a small distribution block, like you would for multiple car audio amplifiers.
Now, if you only want them to come on with high beams, etc, you can also put in a relay.
All a person has to worry about is the type of wire you're using, and watching your amperage so you can determine what strength fuse, relay and switch to use.
So, I'm all set!
unless you are running about 8 sets of 150w lights, I dont think anything will have any problems using 12-14 gauge, depending on how many you want to run.
If you are going to run a lot, use an 8 gauge line to the D-Block, and then 12-14 from there to each set.
An inline fuse in the 8ga, and one in each of the 12-14ga, just for safety imo.
you never know what can happen on 1 set of lights that can affect all of them, unless each is isolated by its own fuse.
LCHEE
10-24-2020 04:10 PM
FlowmasterMufflers
07-17-2015 03:26 PM
