Installing Cam...
Old 01-20-2007, 02:40 PM
TOTM: June 2007
bgray's Avatar
Exclamation Installing Cam...
hey guys..installing my new comp cams soon and my 918 springs. Now..truck is in sig..5.3 rcsb..What other sort of hard parts will I need? any sorta seals, gaskets, whatevers??? Jsut want to amke sure I ahve it ALL ready.
Anyone seen a good walk through on a Cam install on a FSC?? some pics or anything?
thnks
Old 01-20-2007, 02:53 PM
Ascrap2003's Avatar
I think LS1 tech has a walk trough.
Old 01-20-2007, 02:54 PM
LARRY01Z28's Avatar
www.ls1howto.com
its a great write up, its a f-body write up. but its very very good.
Old 01-20-2007, 03:16 PM
Gator's Avatar
The hardest part of the install IMO was removing the harmonic balancer. I was able to do it with a reg. 3-jaw puller but it was damn near impossible...Im sure there is a special puller for it, somebody here will know though. Also installing the balancer was a PITA. you have to get it on far enough in order for the bolt to have enough threads to suck it up. I have heard of heating-up the balancer in an oven to around 200 degrees which will expand it allowing it to slip on ...but I haven't tried it first hand...I called HPE and my machine shop and they both said to beat it on which I reluctantly did worrying about messing up any end play. You "should" get a new harmonic balancer bolt since it's a torque to yield style. Also, right before you pull out the camshaft rotate it around by hand a couple of times. Doing this will seat the lifters in their plastic holding tray, allowing you to pull out the camshaft with out them falling in.
Old 01-20-2007, 03:19 PM
gao8302's Avatar
Get yourself a nice valve spring compressor. VHP has a nice dual spring compressor. Trust me it worth every penny.
Old 01-20-2007, 03:27 PM
TOTM: June 2007
bgray's Avatar
so looks like a front seal thats all?
Old 01-20-2007, 03:34 PM
LARRY01Z28's Avatar
i would get fornt seal and water pump gaskets to be safe. everything else you can 99% of the time re use them.
Old 01-20-2007, 03:39 PM
TOTM: June 2007
bgray's Avatar
Yah i am a bit worried about jsut spinning the cam and yaankign ti out..last thing i want is a lifter to drop out..then im f'd..but the tools are alot of money. safe or sorry???lol...
I was also looking at the crane vavle spring compressor for the LSx's..seems to be a nice piece.
So a front cam seal and water pump gasket? also gonna get myself a fitting so I can comopress the cylinders so the valves dont dump out
Old 01-20-2007, 03:52 PM
gao8302's Avatar
You can also use 5/16 wood or steel dowls to hold the lifters up.
Old 01-20-2007, 04:00 PM
NyteSnyper's Avatar
+1 on the wood dowels... used them successfuly on 3 cam installs...
also a +1 to the Crane Cams compressor... I have it, and it ALSO was used on the 3 installs... did all springs in 10 minutes with the tool to air-up the cylinder to keep the valves from falling... took alot longer the TDC way.
Quick Reply: Installing Cam...
