installing hangers
installing hangers
need some info or a guide to install some hangers on a 00 Silverado ext cab reg bed. going to try and do this on monday or wednesday and i have no idea whats ahead of me
thanks
thanks
first off, jack up the rear of the truck and set some jackstands.(Make sure you secure the truck so it wont roll of while your under it.The easiest way is to borrow a air hammer and knock out the factory rivets. You'll need to move the gas tank over a bit. With the rivets removed you can loosen the bolt that goes through the hanger and leafs. Install the hanger and tighten the bolt to the hanger, jack up the rearend so the leaf lines up with the hole on the hanger and install and tighten. Put gas tank back in place, and move on to the next side. Passanger side is alot easier. If you have any questions pm me
well this is what he bought...the eibach hangers. so thats what we are installing. im concerned about getting the rivets to come loose, and moving the gas tank.. other than that i think i can get this done
anyone else have any tips for me
any body else.. im getting nervous about the rivets.. i think i will try and install these things tomorrow.. any online guides or pics of what i wil be taking off/ changing out...
i dont know about trucks. f bodies.. yes.. trucks NO
any other sites out there that could be beneficial
anyone else have ideas on getting the rivets off...air tools are out of the question.. no one has them that i know
Torch - cut the head off - carefully
14 Second Truck Club
http://www.djmsuspension.com/Instruc...structions.htm
here are some helpful instructions. all the hangers are the same. make sure your doing the front hangers not the rear hangers. i did this job about 2 weeks ago and it SUXS. it took me about 4-5 hrs. you better have a air hammer and a grinder or it will take twice as long as me. Have fun
how much do you guys think a shop like MTI would charge for the instal... those rivets are to tough for me i think and my limited heavy duty tools they said like 2 hours of labor...
FlowmasterMufflers
10-26-2015 06:19 PM
FlowmasterMufflers
08-14-2015 01:04 PM
FlowmasterMufflers
08-14-2015 12:47 PM
lxcoupe
07-21-2015 02:12 AM
FlowmasterMufflers
07-17-2015 03:26 PM
