Installing LS9 head gaskets and ARP studs ?
Old 11-30-2011, 12:17 PM
  #21
ShredSled's Avatar
Originally Posted by zachm89
I honestly didn't even think about it that way with the pistons...guess I'll find out soon enough. As far as the ring lands go I don't really have a plan. My replacement motor only has 50k miles on the clock and I wasn't even planning on pulling the pistons out of the block.
yeah, the lq9 I've been building supposedly had about 50k, but some areas look significantly less, but even still, there was a lot of carbon buildup around the rings I wanted to get off while I was there...
Old 11-30-2011, 12:32 PM
  #22
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
The coating is on the piston skirts not the face of the piston so you're fine. Since you'll have it on an engine stand after you're done spray down each cylinder with non-chloronated brake cleaner then blow it out with compressed air with it upside down. Get the crud off the top ring really well. If you want to throw a couple of those discs in with my cutout wiring I'll let you
thunder550
10-08-2015 04:53 PM
BIGD4504
07-28-2015 11:46 AM
bbowerman
07-26-2015 10:57 PM
black6spdz
07-16-2015 01:32 AM
Quick Reply: Installing LS9 head gaskets and ARP studs ?
