?? on installing the wideband bung into the pipes
Baltimore Whore
Ok I am going to hook the WB up today. I know it should be as close to the head as poss. Isthe reason for this to get a more acc reading or to heat the sensor up faster. I have the rear 02 senors out, so would it hurt to run it in the rear 02 bung... It might sound stupid, but I just fig if it will still give me a acc reading there it would save me a lil work, welding..
Thanks John
Thanks John
Baltimore Whore
Thanks John
On the fuse box at the drivers side instrument panel there is a 10 amp fuse that is switched. You can get a double tap fuse from NAPA, about $40 or Harbor Freight ($8) and use it there. I will look up the fuse number tonight.
zblee
63
06-10-2023 01:25 PM
GXPJAY
02-13-2022 08:15 AM
zblee
08-03-2015 03:45 AM
FlowmasterMufflers
07-17-2015 03:26 PM
