intake
well if your just looking to get the bigger TB, then the TBSS/SSR intake will be alot easier, its a bolt on and alot cheaper than the fast setup. A bare LS2 truck intake is 120 from gmpartsdirect.com.
The fast intake will require a new water pump and idler pulley relocation bracket.
In order to get the TBSS 90mm TB to work you will need an adaptor from www.torquerush.com
Pontiac Derek
09-19-2015 02:49 PM
