Intake for LQ4
Intake for LQ4
Ok, I have an 06 lq4 thats going in my 2000 silverado and I need to make it DBC. Can I change just the tb or do I need the whole intake? I need the return type fuel rail so if I find the whole setup that would be fine. I had one bought from a member on here (00silvylq4) but 10 days after sending the money I have yet to see it and no replies to my messages. So I am on the look again.
I have a gauge for that
So which part do you already have? Your 2000 tb will work on the 06 intake, and I think the fuel rails bolt up the same, you will need a bracket for the 06 intake for the TB cable, I have seen a few... you might have better luck finding a take-off intake from a 99-02 4.8/5.3/6.0, they are all the same.
I should have clarified I am going from a 4.3 to 6.0. So all my parts right now are from the 06 besides a harness from a 99 2wd 2500 because I'm putting in the 4l80 also.
I'll have to look about it being 4 bolt I believe so. If so can I just use a dbc on my intake? Also does anyone have a complete dbc intake laying around including return type fuel rail?
You sound like you are doing the same thing with your truck as i did with mine. I have a 2000 silverado that started life as a 4.3 w/4l60e it now has a 01 lq4 w/4l80e. And again I am sorry for the delay.
Yea thats exactly what I'm doing but I got a 06 motor and trans and my harness I had bought ended up being the wrong thing. So I need a harness if anyone's got one id buy a pcm with it also.
GrooveCityZ71
08-31-2015 12:05 PM
