Intake mani,tb,cam and components upgrade!!!
Alright well its been a while since i had any mods done so i think its time to upgrade the breathing of my engine. Please feel free to give me your opinion on this. If i forgot anything plz let me know tankz. This is the plan so far......
Trottle body: TBSS 90tb
Intake manifold: TBSS
https://www.performancetrucks.net/fo...d.php?t=428860 $200
Heads: Undiceded, open for opinions
Cam: LPE GT2-3 http://www.lingenfelter.com/store/l210085297.html $386.95
Valve springs: Compcams 918 srings Got them free
Lifters: Undecided, open for opinions
Rocker arms: Undecided, open for opinions
Retainers: Prc titanium retainers for 918's http://texas-speed.com/shop/item.asp...d=685&catid=54 $159.99
Pushrods: Does anyone know the formula to get the lenght i need?
Timing chain: Comcams 9-keyway double roller billet timing http://www.compperformancegroupstore...ode=GEN3Timing $122.38
And MAYBE its also time for a smaller pulley
Thanks everyone......and stay tuned!!!!!!
upgrade the headunit... D1 or bust!! Sounds like a good starting point, the LPE cams seem to make good power and have pretty good drivability so thats always a perk. As for lifters, I have a set of Comp 850s that I need to get rid of!! Rocker arms aren't going to help you breathe any better, I honestly wouldn't worry about them unless you just really want to.
smaller pulley = 6-8 rwhp.. if thats worth $200+ or whatever they cost, then have at it?
only way to check PR length is to buy a length checker, and check with the cam installed, as far as i know. generally, a 7.400 will work fine.
stock retainers will also work fine, unless you plan on revving high a lot.. plenty of stock retainers have seen 6400 rpms or more.. titaniums are superior though, for sure.
read my thread about the TBSS intake mani, i still am not sure if its going to gain you much.. you may want to send it out to be ported before installing it, for a few extra hundred.. it may be well worth it. (porting)
good luck on the build.
i would leave the rocker arms alone, and the lifters, unless your engine is a high mileage one...
GrooveCityZ71
08-31-2015 12:05 PM
