Intake manifold flow bench shootout
#23
Originally Posted by treyZ28
Engines are way to dynamic to rate intake manifolds by flow bench results.
#25
FormerVendor
Trey is correct to a point. Still there is some relavent info in comparing the intakes. Remember these manifolds are run dry and the dynamics are different than a wet intake.
I've been thinking about making an adapter to mount the intakes directly to the flow bench bore. That would eliminate the port and would let us get a better look at net runner flow. Now........all I need is time...............
Richard
Richard
#28
Originally Posted by mjhoward
Richard covered that real world testing at the track and dyno could yield different results. I seem to recall that someone recently on here picked up .4 secs in the 1/4 with a regular LS1 intake swap which flows less than the truck on the flowbench. Reguardless, it is still good info. The flowbench can't measure the total flow of 8 runners and the change in dynamics as rpms increase. An intake works as a harmonius unit rather than an idividual runner like a head can be measured.
#30
Kano has an LS6 intake on his truck. The LS1 is a little less efficient as seen on th eflow chart.
