Intake Manifold Suggestions
Ive started shopping around for an intake manifold that im gonna pair up with some 243 heads. Ive been thinking about these two...
http://www.summitracing.com/parts/edl-7139/overview/
http://www.summitracing.com/parts/hly-300-123/overview/
Does anyone have these and if so do they work well and if no one has them does anyone know anything about them? Also does anyone have any other recommendations? They are about the same price when u factor in the fuel rails as the holley comes with them and edelbrock doesnt. I was orriginally thinking about a tbss intake but not sure now. As far as power i would like to keep it in the low-mid range, thats why im not considering an ls6 intake or similiar. I have the stock 78mm tb that i will p and p and i also have a 87 or 90 tb? which came off of an 07 tahoe with the 6.0. near soon future mods will be a bigger cam, a stall, and spray. any help or suggestions would be appreciated, thanks!
For the future mods you listed I honestly think a ported TBSS intake with a 92mm TB will do more than fine bro Holley intake is good for high rpm ranges, the Pro-Flo EFI is also a good intake but i think you could benefit more than good with a TBSS intake.
are you talking about the fast car intake or truck? i heard they were junk cuz they never fit right or always leaked? is the tbss the same as the nnbs intake? also i may have the wrong info but my stock tb is a 78mm but i also have one off of an 07 (i think) tahoe with a 6.0...thats an 87mm or a 90mm right?
I would stick with the TBSS intake as well. In theory, it would suite you better. The TBSS intake is the same as the NNBS. I got mine off of ebay for $150 shipped. You will want to upgrade to the 90mm tb when you do the swap to make it worthwhile.
A lot of guys have issues with the truck FAST manifold and some don't. Its a drop in a bucket but I've never heard anyone complain about the TBSS intake. Especially since it is so cheap vs going aftermarket.
whats about the holly mid rise instead of the high rise?
http://www.summitracing.com/parts/hl...make/chevrolet
how ever the tbss intake would be good also.
Mid rise will make even less torque, the pro flow is a good intake for a stroker motor spinning to 7k or 6.0 going to 7000-7500, the holley is made to pull to 8k. These intakes and kind of like huge cams for these truck's, looks promising on a dyno but real world performance you gain 10hp up top and lose 10hp down low. The factory intakes flow plenty the only reason to ever change it is to change the power band. Look at some of this turbo stuff 1000rwhp on stock intakes that tells you they can move air.
