intake manifolds
On LS1 motors doing the swap without a cam is usually only good for about 8-10HP. Doing the sawp with a big cam can be worth as much as 15-20hp. So yes it is worth it if you are going for max N/A power
You will do well with the stock truck intake under boost. The Delphi 42lb hr injectors plug in and idle awesome. If you going to need more injector the Mototron 60's idle well also. They need a spacer to move rail up and a different plug than the truck has.
Kurt
Kurt
Originally Posted by 01Blackerado
im going for max trubo power lol and this is on a silverado 01 5.3
Adkoonerstrator
Look in here to see what is involved with swapping over to the Delphi injectors.
https://ls1tech.com/forums/showthread.php?t=86396
