Intake Manifolds: LS1, LS6, Or Stock Truck....
Old 11-26-2004 | 04:18 PM
IMD's Avatar
IMD
Banned
Default Intake Manifolds: LS1, LS6, Or Stock Truck....
lets rate them on flow....what would work best for forced induction, any dyno testing between the stock truck, and the others?
hooray!
Old 11-26-2004 | 04:25 PM
ktmrider's Avatar
hooray!
LS6 has best flow from 3000 rpm up, average of 6+ HP over the range. Overall the stock truck manifold is very good and even flows best at lower rpms. If you go FI the LS6 one is best IMHO. I think Car Crafters or Hot Rod did a very good article on the LS1 style manifolds with all of them doing well, even compared to the LSX aftermarket. Truck manifold will not fit under the hood of the F bodies tho ( too tall ).
Oh, and you would need to change to a car water pump and use a return style fuel rail if you want to put LS1/6 manifold on the truck.
Old 11-26-2004 | 04:34 PM
IMD's Avatar
IMD
Banned
what about the single plane carb style manifold, converted to injection?
Old 11-26-2004 | 06:25 PM
GoldenVelvet's Avatar
The aluminum carb style can be ported a lot more then our nylon intakes, and they out flow all but the ls6 so that helps make them more popular with the F/I guys. However, they are expensive once you figure in the work to convert them back o EFI, and aluminum retains heat, which is something that you will be battling with forced induction.
Old 11-26-2004 | 07:15 PM
XLR8NSS's Avatar
Adkoonerstrator
The aluminum carb style also seems to have some distribution problems(outside cylinders) on NA engines. On FI engines I don't think it's as much of a problem. Here are some flow numbers for each type of manifold attatched to a set of LS1 heads(I think that is correct).
LS1 Intake
.200 .300 .350 .400 .450 .500 .550 .600
141- 185- 205- 222- 232- 241- 251- 258
Truck Intake
163- 206 -224 -237 -249 -262 -265 -270
LS6/00-02 Intake
166 -211 -229 -244 -257 -269 -277 -283
Old 11-26-2004 | 10:46 PM
silent1's Avatar
The best for manifold for boost IMO is a custom sheetmetal intake. VERY pricey, but well worth the money for an all out FI application.
Old 11-27-2004 | 05:32 PM
StupidFast's Avatar
Anyone else notice that the truck intakes funnel down about 5 inches into the throttle opening? Also the egr block-off is sticking 3/4 of a inch into the throttle opening.
Just somethings I have noticed and will quickly fix.
Old 11-27-2004 | 06:17 PM
Sport Side's Avatar
Hmmm, good comparison X-cel. To bad you weren't selling your LS6 for about $150
btw....you wouldn't happen to know the runner length of all 3 would you? Similiar?
Kyle
Old 11-27-2004 | 10:47 PM
XLR8NSS's Avatar
Adkoonerstrator
Kyle
The truck runner looks like it's a good bit longer than the LS6. The info might be on the site somewhere if you search hard enough. If not I could probably get it sometime next week.
Old 11-27-2004 | 11:41 PM
StupidFast's Avatar
I have have researched the truck intake alot. Here is what I found on a older thread:
ls1 & ls6 intakes have a runner of 262mm and the truck one is 263mm
The runners are the same length but, the runners on a truck start at the center of the intake. After the air gets pulled through the TB opening and 8 inchs to the center. I think they measured from the start of the runner instead of the actual air path.
Quick Reply: Intake Manifolds: LS1, LS6, Or Stock Truck....
