Intake questions
just buy some pipe at home depot and some of these silicone adapters if your going to part them together. also i wouldn't worry about cutting the air box as once you do you will be sucking up hot air inside the engine bay and it wouldn't be as good. it might start to pull timing as the temps rise. now if you take the time to plumb it so its also pulling from the out side like the tow hook hole that may work. i just don't see doing all the work when its only going to maybe give you 2hp if your lucky on the top end.
http://www.siliconeintakes.com/stpg....=silicone_boot
i put an airaid tube, filter and box in my truck and its a 2010 so if you want the box I took out your welcome to it, but I must say I love my set up, it helped a lot and I don't have to worry about water getting in the box and killing my engine like my friends do
