intake swap
Registered User
intake swap
i have a 2005 gmc 1500 with the 5.3 coldair intake mild ex. want to swap the intake with an intake from a 2002 camaro z28 wondering if i can use the same injectors or do i need diffrent ones.
Baltimore Whore
While that is a good intake there is a TON more to it then swapping. You need relocation brackets and all. Best bet is to sell that ls6 intake, get a TBSS intake. Much less headache and makes more power. Not to mention you need to run car style injectors or buy pig tails connectors to use the car injectors. Do a search for ls6 swap and you will find a ton of info.
GrooveCityZ71
08-31-2015 12:05 PM
