jag performance 80e is here!!!
#31
13 Second Truck Club
Originally Posted by 02denali
taillights huh. NEVER. i will send you a pic of the rear of my truck so that you will have deja vue every time we race.
#32
Formerly one92rs
either run me how i am or add 800 pounds to your truck. or just accept the fact that i am faster.
on the cats i had it without cats before this.little loud on trips and i will give a little hp to them. now i can get it inspected anywhere.
#33
#35
Originally Posted by HemiTman
800 lbs huh?? Well, I don't know if my GF will be avaliable that night...........LOL
#37
Formerly one92rs
thats ok man. i weigh in at 4950 pounds. you are lighter with a bigger engine. i will race you anytime anywhere. we can try with and without spray. hell it will be good just to get back on the road for now.
now. on the crossmember--i put it on the trans and lifted it up to position. found that the hd crossmember lifted the tranny to high. i believe that this is due to it coming out of a hd. the frames are bigger. i did manage to get the frame drilled. i had to cut some more of the old mounts out in the back on the inside of the frame to gain access to the bolt holes. drilled them out to 1/2". removed it after measuring it and had to cut it down 1 3/8 of an inch. i tacked it in place. i am going to take it to work and finish welding it. i will get picks later today.
