JBA Headers Shorties, How much to pay for install ?
Before i hear the i should of not bought them ,should of got the LT. I live California and in order to pass smog i need legal headers and these will do fine. I would of love LT,but this is my best option.
Now I will be getting them tomorrow. I asked the shop that order them for me how much to install he said $500 and if i want 3 year warranty in case a bolt or gasket goes bad. It would be another $100, I asked if thats the best they can do he dropped the price to 460 install and plus the 100 if i want warranty.
Is the 460-500 quote too much ?
Thanks in advance .
Truck is a 2006 1500 Vmax
Thanks in advance .
If you are slightly mechanically inclined than you can install these yourself. They are really easy to install, the hardest part is taking the manifold bolts out. Spray them down with a lot of penetrating spray. Can't think of the name of the one that eats a styrofoam cup up, but it works good. Let set for 5 and then spray again and they should come off easy. The problem with a shop doing it they might just break a bolt in the head and you will not know it.
JBA Shorties
I did mine in my garage. No matter how much PB Blaster I used, I still had to grind off one header bolt on the driver's side. Other than that, it was fairly easy. Certainly no $500 job!
I understand the smog situation. Where in CA are you?
