junkyard lq4
junkyard lq4
Found a lq4 in a junkyard for $300 its a complete block no heads or anything up top it has 150,000 miles is this a good deal? what all should I look for as far a damage wise and what kind of heads should I go with if I do buy this motor?
If there does happen to be water damage would I be better off just buying a complete motor with high mileage and just tear down clean it up fix what needs to be fix
it really depends on how bad it is. you won't be able to know until you see it and can inspect. it might be able to clean up fine or it may be hopeless, either is just as likely.
calsdad
06-14-2023 11:07 PM
lxcoupe
09-29-2015 09:20 PM
