junkyard ls1 or 6.0
Old 10-31-2011, 01:34 PM
Woodlandcritter's Avatar
Default junkyard ls1 or 6.0
have a shortcab with the 4.8 and its lacking on the lower end power and is starting to burn oil. so which motor should i go with. dont wanna get into changing cam, springs, ect yet.
Old 10-31-2011, 03:16 PM
13 Second Truck Club
grey matter 04's Avatar
6.0s are usually cheaper and easier to find
But either one will do great
Old 10-31-2011, 03:32 PM
what would be the benefit of the all aluminum block and 243 headed ls1 to the all cast iron 6.0s. i know theres no replacement for displacement but doesnt the ls1 have a pretty good cam and heads to begin with verses the 6.0 which would need that. am i better off getting a 6.0 for 1 k putting 1k in cam and valve train upgrades or spending 2k on an ls1?
Old 10-31-2011, 03:54 PM
the standard LS1 doesnt come with 243 heads an LS6 does thats even more$$
An iron headed 6.0 is a 99-00 model and has a longer crank shaft that will not work with a 4L60E based tranny
Old 10-31-2011, 04:16 PM
looks like i have much more research to do......lol thanks
Old 10-31-2011, 04:20 PM
Fastcount03's Avatar
Find you an 05+ 6.0, LQ4 or LQ9, swap it out, tune it, and be done with it. You won't be disappointed.
Old 10-31-2011, 04:26 PM
chevyboy.520's Avatar
Old 10-31-2011, 04:47 PM
I do things different i would choose the LS1
I also feel the ls1 will make a few more HP
WHY? LS1 with tr224 cam and full bolt-ons many have made 400hp with them
6.0 same setup 380hp takes a good set of cylinder heads to break 400
I think the LS1 gun drilled light weight crankshaft causes the difference.
Yes the 6.0 will make more torque because of cubic inches
They both good motors i dont feel one is that much better than the other.What ever one is more availbe and in price range is what i would choose!
Old 10-31-2011, 04:59 PM
seems that any 05+ lq4 or lq9 is about the same price as a ls1. this is gonna be a hard choice. im unsure about the electronic throttle on the 05 up. do you guys use it or convert somehow?
Old 10-31-2011, 05:04 PM
just use your intake and throttlebody on the new motor solves that issue
Quick Reply: junkyard ls1 or 6.0
