junkyard ls1 or 6.0
I do things different i would choose the LS1
I also feel the ls1 will make a few more HP
WHY? LS1 with tr224 cam and full bolt-ons many have made 400hp with them
6.0 same setup 380hp takes a good set of cylinder heads to break 400
I think the LS1 gun drilled light weight crankshaft causes the difference.
Yes the 6.0 will make more torque because of cubic inches
They both good motors i dont feel one is that much better than the other.What ever one is more availbe and in price range is what i would choose!
If you happen to find the LS1 Cheaper than the 6.0 I'd prob go with that just to be different. Almost all the guys go for the 6.0's. Usually because the LS1's are same price or more expensive sometimes. Every now and then you will come across a cheap LS1 though. I saw one local on craigslist about 4 months ago for $350 or $400. It was the complete block with no accessories or pcm which is fine, you can reuse the 4.8L accessories and pcm. Just get the pcm tuned.
I actually found one 30-45 mins away for $300, but the listing is 2 months old.
Goes to show you deals can be found.
GMCtrk
18
10-06-2015 03:48 PM
Cammed4ever
09-30-2015 03:38 PM
