junkyard ls1 or 6.0
Old 10-31-2011, 05:08 PM
Woodlandcritter's Avatar
thats easy enough. just how much better is the 05 + motors vs like an 02 its a 1000$ difference in price
Old 10-31-2011, 05:11 PM
13 Second Truck Club
grey matter 04's Avatar
they are the same
mileage is whats affecting price i bet
Old 10-31-2011, 05:55 PM
9 Second Club
Rhino79's Avatar
Compression is better on a stock ls1, but a stock 6.0 has better flowing heads in the 317's vs the 241's. Mill the 317's, throw on an ls6 intake and let her rip. That combo will be stronger than a ls1.
Old 11-01-2011, 08:48 AM
Gordy M's Avatar
If you get a LS1, get the 01+ as they had the same intake as the Z06.
Old 11-02-2011, 08:47 PM
sand man's Avatar
Originally Posted by grey matter 04
I do things different i would choose the LS1
I also feel the ls1 will make a few more HP
WHY? LS1 with tr224 cam and full bolt-ons many have made 400hp with them
6.0 same setup 380hp takes a good set of cylinder heads to break 400
I think the LS1 gun drilled light weight crankshaft causes the difference.
Yes the 6.0 will make more torque because of cubic inches
They both good motors i dont feel one is that much better than the other.What ever one is more availbe and in price range is what i would choose!
more about the ls1 crank please?
Old 11-02-2011, 11:02 PM
its gun drilled so its lighter than a 5.3/6.0 crank
less rotating mass!
Old 11-02-2011, 11:06 PM
jrmchevyman's Avatar
If you happen to find the LS1 Cheaper than the 6.0 I'd prob go with that just to be different. Almost all the guys go for the 6.0's. Usually because the LS1's are same price or more expensive sometimes. Every now and then you will come across a cheap LS1 though. I saw one local on craigslist about 4 months ago for $350 or $400. It was the complete block with no accessories or pcm which is fine, you can reuse the 4.8L accessories and pcm. Just get the pcm tuned.
I actually found one 30-45 mins away for $300, but the listing is 2 months old.
Goes to show you deals can be found.
GMCtrk
18
10-06-2015 03:48 PM
turbo6c3
10-05-2015 06:11 PM
Cammed4ever
09-30-2015 03:38 PM
trevorh1
09-27-2015 08:47 PM
sTNT971
09-26-2015 04:22 PM
Quick Reply: junkyard ls1 or 6.0
