Just did a cam
Took the thing back apart to check timing and this is what it looks like. The plugs are really black. I think I should rotate the cam gear a tooth
Yea it is definitely dumping fuel for some reason. Can you keep it running long enough to spray brake cleaner around the intake? If the engine RPM rises, there is a leak. It just sounds like an intake port needs to be capped.
The pics you tried to upload don't show up for me btw
11 Second Club
Mike
It will barely even start at all now. When it does it will run for about a minute if you keep your foot on the gas. I cleaned maf with mad sensor cleaner and yes it's installed corrctlly
