Just got my efi live cable, went and wasted a couple gallons of gas :)
if your in 4th gear, TC locked up at like 70 MPHish, its pretty easy to get it to kick up a little KR, mine will do it as well. I wouldnt worry about it to to much.
what pids are you logging?
If you log tcc mode, and I think GM.GEAR you can know if the TC is locked up as well as if the trans was commanded to shift, if both the the MPH paramater and RPM parameter are met you just have an old stockish 60e, it will shift sloppy as far as timing goes.
