Just got my efi live cable, went and wasted a couple gallons of gas :)
Old 04-18-2009, 10:52 PM
GMCtrk's Avatar
also, I'm getting KR. For example, just on the drive home I didn't go past 50% TPS, and at one point it showed 3.2 deg of KR??? wtf. Shell 93 octane gas. I guess the tune is no good with the 10.6-7:1 compression
Old 04-18-2009, 10:58 PM
Truck Sponsor
Wheatley's Avatar
Keep messin with it,you will get the hang of it!Takes time and patience.
Old 04-18-2009, 11:09 PM
GMCtrk's Avatar
right now I'm off to the casino to get rid of this $500 burning a hole in my pocket.
Did i mention I was up $1050 there last night and lost it all. lol
Old 04-18-2009, 11:21 PM
Wearin' da big hat
00ChevyScott's Avatar
If you win anymore money you're buying me EFILive V1....deal?
Old 04-18-2009, 11:24 PM
Truck Sponsor
Wheatley's Avatar
What do you use now Scott?V2?
kbracing96's Avatar
Sounds like you need to work more on your money management while gambling then your tune
Old 04-18-2009, 11:30 PM
Wearin' da big hat
I've been using Corey's V2 cable when we go logging/tuning.
I really need to get my own so I don't have to go out and bug Corey all the time to load tunes
Old 04-19-2009, 03:17 AM
GMCtrk's Avatar
Just got back from the casino. Lost 500. Now I dont have to worry about going back.
Could someone please take a look at the tune and see what's wrong with the shifts.
Old 04-19-2009, 07:35 AM
dlt76028's Avatar
could of done a cam swap with that and be fast
Old 04-19-2009, 08:16 AM
charcold-bowtie's Avatar
if your in 4th gear, TC locked up at like 70 MPHish, its pretty easy to get it to kick up a little KR, mine will do it as well. I wouldnt worry about it to to much.
what pids are you logging?
If you log tcc mode, and I think GM.GEAR you can know if the TC is locked up as well as if the trans was commanded to shift, if both the the MPH paramater and RPM parameter are met you just have an old stockish 60e, it will shift sloppy as far as timing goes.
Quick Reply: Just got my efi live cable, went and wasted a couple gallons of gas :)
