Just installed 6.0, getting misfire/flashing SES light.
Old 03-20-2010, 05:32 PM
  #21
13 Second Truck Club
DV2000NJ's Avatar
Originally Posted by GMCtrk
Nope, fired right up perfectly.
I'd say you're problems are due to the open headers. How come you haven't bolted up the OBX y pipe?
The headers I got are the ones that are essentially stainless Pacesetters (EGR port, 3" slip-fit collectors, same pipe routing), and they didn't come with a Y. I'm going to a buddy's house tomorrow to modify the stock Y.
  #22
GMCtrk's Avatar
If that's the case just buy a Pacesetter Y pipe. It should bolt right up since those headers are copies of pacesetters
Old 03-20-2010, 05:33 PM
  #23
DV2000NJ's Avatar
Originally Posted by dlt76028
No it will flash p0300. mines done it multiple times
Hm... Learn something new every day.
If it were a cracked plug though, it wouldn't be RPM dependent, would it?
Old 03-20-2010, 05:36 PM
  #24
DV2000NJ's Avatar
Eh, cutting/welding up the stock Y is cheaper, and I want to run cats.
Old 03-20-2010, 05:42 PM
  #25
dlt76028's Avatar
I had a cracked plug that would drive fine until higher rpms and it would start popping.
Old 03-20-2010, 05:48 PM
  #26
DV2000NJ's Avatar
Hm... That'll be the next thing I check after the exhaust is straightened out.
And I might as well ask you too, when you did your swap, did you need to get a CASE/crank relearn done?
Old 03-20-2010, 05:49 PM
  #27
dlt76028's Avatar
No.....
Old 03-20-2010, 05:55 PM
  #28
DV2000NJ's Avatar
Cool, thanks.
And thanks for all the input guys, I really appreciate it.
Old 03-21-2010, 03:12 PM
  #29
DV2000NJ's Avatar
Exhaust is on, misfire is gone, and everything is perfect. Well, except for the oil leak from behind the oil cooler block off plate. Yes, I forgot the gasket.
Old 03-21-2010, 05:23 PM
  #30
jhe2003's Avatar
Congrats!
Quick Reply: Just installed 6.0, getting misfire/flashing SES light.
