Just installed 6.0, getting misfire/flashing SES light.
Old 03-21-2010, 09:18 PM
  #31
PT's Slowest Truck
budhayes3's Avatar
Good job Dan, congrats! Now get back to school and learn something...you younguns are our future!
Old 03-21-2010, 09:50 PM
  #32
fredkj3's Avatar
man glad you found it... crazy to think that open headers was causing all that trouble.. good to know... ha... i had a very similar issue.. when i put the cam in it would miss under load... and i had a broken spark plug.... glad you figured it out..
Old 03-21-2010, 10:03 PM
  #33
13 Second Truck Club
DV2000NJ's Avatar
After driving a bit more, it turns out that the misfire isn't COMPLETELY gone.
A couple times at idle, it came back. Once I started driving, it stopped missing, SES light went away, and when I cleared the code, it didn't come back for another 20 miles or so.
I'm thinking the CASE relearn may still need to be done, but if I get some time this week, I'll go over all of the plugs and see if any are cracked, but that really doesn't seem to be the case, since it's fine under load, and only occasionally misses at idle.
Old 03-21-2010, 10:04 PM
  #34
GMCtrk's Avatar
Notice any power difference
Old 04-04-2010, 03:01 AM
  #35
hobbesnmina2001's Avatar
I started getting ticking sound on the drivers side like an exhaust or lifter and got the p0357 which says #7 P0357 (Ignition Coil G Primary/Secondary Circuit Malfunction). I need to check it out, has anyone experienced this before?
Its a 2003 6.0 L Silverado ~76 thousand miles stock. I thought the stock lifters/rockers where pretty good usually?
My scanner does show the misfire count on #7 up.
Old 04-04-2010, 05:29 PM
  #36
Thumbs down
I think mine is a bad wire on #7. I took off #7, and #3 plugs and they did not look much different both clean and dry. Put on Ohm meter on both wires and they had similar resistance with # 7 moving a bit higher around 100 here and there.
I switched coils plugs and wires, cleared the code and restarted, the code and missfires moved to # 3. I switched the wires only back and it seems a little smoother but it did that before without doing anything to it. I will drive it to work and but I am thinking the code will move back to #7 and it will be the wire. Its the factory wires and plugs with ~76, 000 miles but close to 7 years old, harder on the wires. I will get a good set and put them on. The resistance was 595 with # 7 595-700 ohms. ~100 ohms is around 17% higher resistance over the lower ohm rate on both wires. Although I could not see a spark at night moving around that ticking sound might be a bad shielf somewhere on the wire. Today we drove it a little before the work and you could feel the hesitation miss come and go.
If it was the hydraulic rolller or rocker it would be consistent and this comes and goes.
Old 04-05-2010, 12:18 PM
  #37
Registered User
FNGtotheLS2's Avatar
it could be a vacum leak, i have the same problem on my lq9 swap into a firbird, got it tuned and found the leak, since then ok
Old 04-05-2010, 11:06 PM
  #38
The miss fires moved over to #3 so I don't think its vacuum leak, although that thought had crossed my mind at first.
I switched the wires only back. It is still miss firing on #3. I am going to put a set of wires on it and if the miss still there will try a new plug, after that it can only be the coil.
Old 04-08-2010, 12:12 AM
  #39
I put new MSD wires in today and the problem was solved. The new MSD's measured at `46 ohms vs ~595 plus for the old ones!
The plug was the original # 7 plug which did not look much different but must have had something because it was still miss firing just a little bit at first. As the engine warmed up and I goosed the gas a little back and forth the miss went away completely and its running like new, you could almost stand a nickel sideways on it!
I got new plugs but since the originals are working well and looking clean I will leave them in a while longer.
Corvette454l88
09-01-2016 01:24 AM
all_individual
10-10-2015 10:09 PM
stock48
11
08-18-2015 05:55 AM
rojeho
08-08-2015 07:20 PM
all_individual
07-13-2015 11:01 AM
Quick Reply: Just installed 6.0, getting misfire/flashing SES light.
