Just put in a new motor, Big problem
Old 03-30-2010, 10:44 PM
  #21
dlt76028's Avatar
Originally Posted by THE-HOE
Video is at this link on you tube, thanks for all who are trying to help
http://www.youtube.com/watch?v=W2fQtBaAAso
sounds like a rod bearing to me man.
Old 03-30-2010, 10:53 PM
  #22
dirt track racer 81's Avatar
ahh, i hope that's not it. I noticed that my tick is a lot faster and more high pitched than that sound from the corvette. I was always told that rod bearings and main bearings will be a more deep tone compared to a bad lifter sound. Who knows how true that is though
I agree with you, to me it doesnt sound like a rod bearing.. did you actually try to move any of the rockers to see if there was any play? Did you roll the motor over and watch the rockers and see if there was one that looked odd?
  #23
THE-HOE's Avatar
[QUOTE=dlt76028;4428393]Definitely sounds like a rod bearing to man.[/QU
Oh boy, i was hoping more people wouldn't think so. Im assuming there isnt really any tests I can do to make sure without actually taking it out?
Old 03-30-2010, 10:57 PM
  #24
SLOXCAB's Avatar
rod bearing or wrist pin maybe
Old 03-30-2010, 10:58 PM
  #25
THE-HOE's Avatar
Yes, I have and I really didn't notice anything. Lets say that I stop the motor while a certain spring is compressed so a valve is open, and the spring slowly starts to de-compress by itself closing the valve and pushing the push rod back down. Is that just because the lifter isn't pumped up with oil, or could that mean the lifter is bad?
Old 03-31-2010, 01:29 AM
  #26
GFYS and STFU
Spoolin's Avatar
Kinda sounds like what my old truck sounded like when I was low on oil, turned out to be the tappets. Stupid question but have you checked your oil?
http://www.streetfire.net/video/clic...-ma_127334.htm
Old 03-31-2010, 11:17 AM
  #27
PT's Slowest Truck
budhayes3's Avatar
Sounds like a rod bearing to me, listen to the speed of the noise, it sounds to be the same speed of the crank shaft. Short out the cylinders by either unplugging coils or injectors one at a time. When the noise goes away, you've found which cylinder is the culprit. Then you can pull the oil pan and the rod cap and you'll probably find a spun bearing...just my opinion...
Sucks dude, sorry to hear this
Old 03-31-2010, 11:42 AM
  #28
MikeGyver's Avatar
I don't think it is a rod or piston pin bearing, it is too crisp. It would be duller if it were in the bottom end. I know it sounds like it is at crankshaft speed, but I still think it is in the valve train. Maybe two lifters. Or maybe that nut you lost is stuck in the top of a piston!
Old 03-31-2010, 02:28 PM
  #29
BlownChevySS's Avatar
You could always pull the valve covers and run the truck to make sure oil is pumping up. I did it when I heard a ticking too. You just have to ziptie the coils to hold them up.
Old 03-31-2010, 10:29 PM
  #30
my black ss's Avatar
nothing works better than unpluging those wires if the noise dosent stop on any its a lifter ...ive never heard a rod that high pitched but i have heard a bent valve sound that way works easy enugh bent valve will make the spring be pressed a lil and create excess play in a lifter/rocker
Quick Reply: Just put in a new motor, Big problem
