Just put in a new motor, Big problem
Old 04-01-2010 | 01:01 AM
  #31
454SuperSport's Avatar
pull the pushrods back out and make sure nothing is stuck inside of them. sounds like a rocker arm is running dry, or either someone forgot to tighten the torque converter bolts
Old 04-01-2010 | 07:05 AM
  #32
THE-HOE's Avatar
Sounds like a rod bearing to me, listen to the speed of the noise, it sounds to be the same speed of the crank shaft. Short out the cylinders by either unplugging coils or injectors one at a time. When the noise goes away, you've found which cylinder is the culprit. Then you can pull the oil pan and the rod cap and you'll probably find a spun bearing...just my opinion...
Sucks dude, sorry to hear this
Thanks for the info. I will try this on my lunch break today. Im hoping for the best whatever that is.
Old 04-01-2010 | 07:57 AM
  #33
TIM Z's Avatar
11 sec. Truck Mod
Man im hopeful its not a bearing, sounds like lifter/ rocker arm noise to me.
Good luck
Old 04-01-2010 | 11:12 AM
  #34
budhayes3's Avatar
PT's Slowest Truck
Yea, if the noise is still there when you short out the cylinders, you shouldn't have a rod bearing problem, if it goes away, you narrowed down which cyl it is, and you may be in for some bottom end work...I have my fingers crossed for ya and I'm hoping for the best, good luck
Old 04-02-2010 | 06:47 AM
  #35
THE-HOE's Avatar
Well i got the head off yesterday and took out the lifters, come to find one lifter completely collapsed. It has definitely never pumped up so I am happy to say that is guaranteed my problem. Thanks to everyone who helped with this. Now I put it back together and start the turbo install.
Old 04-02-2010 | 07:34 AM
  #36
03sierraslt's Avatar
Good deal man, glad you found it.
Old 04-02-2010 | 12:39 PM
  #37
Spoolin's Avatar
GFYS and STFU
Pictures of the lifter?
Old 04-02-2010 | 04:17 PM
  #38
00Silv4.8's Avatar
exactly what I thought.
Apparently these guys have never heard lifter chatter vs rod knock except on youtube. Even then they are NOTHING alike.
Glad it was a lifter after all man, new lifters and give her hell!
Old 04-02-2010 | 05:36 PM
  #39
budhayes3's Avatar
PT's Slowest Truck
Heard em both my brother, many many times (been doing this for a living for a long time)...the speed of the sound is what got me, sounded like crankshaft speed to me. Unfortunately, I don't get the real sound on youtube through my laptop, so I do better in person Glad that I was wrong though, a lifter is an easy and inexpensive fix
OHsixLS3
12-27-2016 09:30 AM
jmarkway
07-18-2015 09:23 PM
grantpo
07-15-2015 12:21 PM
davis28905
07-08-2015 03:20 AM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: Just put in a new motor, Big problem
