Kill Speed Limiter
Old 08-07-2003 | 04:05 PM
Cal's Avatar
Cal
Default Kill Speed Limiter
My '02 Duramax truck seems to have a speed limiter at 95 mph. Anybody know how to disable the limiter?
Old 08-07-2003 | 04:09 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Default Re: Kill Speed Limiter
My HPP3 took away the speed limiter on my truck.
Old 08-07-2003 | 04:18 PM
TG02Z71's Avatar
Predator.......HPP3....edit...
Old 08-07-2003 | 04:27 PM
Cal's Avatar
Cal
I have LS1edit, but I didn't think that worked on the Duramax. I can't bring up the Carputing site from my work computer; do they have a special version for the Duramax?
Old 08-07-2003 | 04:46 PM
onyx's Avatar
14 Second Truck Club
did it take it away literally, or did you just raise it higher?... because all mine did was raise it to 128...
Old 08-07-2003 | 04:47 PM
Hit Man X's Avatar
EDIT doesn't work on the DMax. What you want is the Duramaximizer and the Tech IV box. That will give you two ***** for 0-100HP and another 40-168HP that can be stacked together! and your 120MPH speedo
http://www.pacificp.com/cgi-bin/cat/DU-PCM-PP-1.html
Old 08-07-2003 | 05:01 PM
Cal's Avatar
Cal
OK thanks, Hit Man X! WOW that's a pricey box at $2040! And if I understand correctly, it only raises the speed limiter to 120 mph. I was going to try and get the truck up to 130 mph on Speed Week out at the Bonneville Salt Flats. I'm also wondering if I can do that on the stock 300 hp. If I can, maybe it would be cheaper to just slow down the VSS pulse train to the PCM so computer still thinks the truck is going less than 95 mph.
Old 08-08-2003 | 04:06 AM
Flyer's Avatar
Try unplugging the VSS cable .. try that out. I think I saw in Edit (if I understood right) that the truck tables for shifting and speed are thrown out and use a seperate set of shiftpoints and rev limiters if the VSS is bad. Just carry a GPS with you .. and you should be fine.
Old 08-09-2003 | 01:28 AM
Cal's Avatar
Cal
Thanks Flyer, that's a good idea. Good information also. The problem now is the wife says I'm not running the truck she helped pay for at the Salt Flats!
Old 08-09-2003 | 02:40 AM
No, it took it away figuratively.
I set it to 128 I think. Doesn't really matter though here in So Cal. The section of the 101 freeway I drive daily on you can never go that fast (safely ) unless its 4am. Every other time its jam packed.
bearden86
26
11-15-2015 04:58 PM
turbo6c3
10-05-2015 07:11 PM
BlownHD
10-03-2015 01:24 PM
Lthompson
10-02-2015 01:45 AM
Rockrz
09-29-2015 10:07 AM
